X440-G2 intervlan routing
  • Question
  • Updated 3 months ago
  • Answered
Could X440-G2 series supports Inter-VLAN routing? is this manageable switch?
Photo of Alok Shukla
Alok Shukla
  • 834 Points 500 badge 2x thumb
Posted 3 months ago
You just mean VLAN A and VLAN B to be routed on a X440-G2?
Yes, of course.
https://learn.extremenetworks.com/rs/641-VMV-602/images/ExtremeSwitching-X440-G2-DS.pdf
"The X440-G2 Series supports sophisticated and intelligent Layer 2 switching, as well as Layer 3 IPv4/IPv6 routing."
http://extrcdn.extremenetworks.com/wp-content/uploads/2014/04/ExtremeXOS_Feature_License_Requirement...
IPv4 unicast routing, including static routes: All platforms that support the Edge, AdvancedEdge, and Core licenses (see the following table).
Regards Micha
Photo of Andre Brits Kannemeyer
  • 4,888 Points 4k badge 2x thumb
Hi Alok
Yes this is a fully managed switch.
You can assign IP's to each vlan and then enbale "IP forwarding" to allow routing between vlans.
For more advance routing like OSPF you can add the "Advance Edge" license.
Regards
Photo of Claudio D'Ascenzo
Claudio D'Ascenzo
  • 402 Points 250 badge 2x thumb
Yes is manageable via CLI, Telnet, SSH and SNMP, the default XOS license is Edge that support.
•Layer 2 switching with Layer 2-Layer 4 QoS, EAPS-edge, STP, RSTP, PVST+, 802.1s, etc.
•Basic Layer 3 routing capability for IPv4/IPv6 with RIPv1, v2, RIPng
Upgradable
Advanced Edge, AVB and OpenFlow
Regards
CLaudio
Alok Shukla
Does it Support VRRP?
Claudio D'Ascenzo
yes with advanced Edge XOS license
Supported Limits for Advanced Edge License
regards Claudio
