X440-G2 port license upgrade
  • Question
  • Updated 1 year ago
  • Answered
  • (Edited)
I am confused over the licence required to upgrade a X440-G2-48P-10GE4 switch , so that the 2 copper ports can run at 10G rather than IG , the document details to licence upgrades one for 4 ports and one for 2 ports which which is 16542. Basically I need too connect by 10Gig copper ( X670V-48T which I have in the core .
Thankd in advance
Photo of Rod Robertson
Rod Robertson
  • 2,344 Points 2k badge 2x thumb
Posted 1 year ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,486 Points 10k badge 2x thumb
Hi Rod,
I checked into this, and it does look like the 2 copper 10Gbase-T ports should be covered under the 2 port 10G license.
-Brandon
Photo of Donna Rupert
Donna Rupert
  • 240 Points 100 badge 2x thumb
You do not need the 10 gb license to support Summit stack -V  to the X670. The nine switch models can support 10Gb stacking (SummitStack-V) across two of the 1Gb
SFP ports. These ports run a 10Gb stacking protocol by default so a 10GbE license is NOT required.
Photo of Alexandr P
Alexandr P, Embassador
  • 12,670 Points 10k badge 2x thumb
Hello, Rod!
But you have to remember that if you stack X440 with X670, stack performance will be based on X440 (FDB, LPM etc.).
Thank you!
Rod Robertson
Hi , I don't want to stack , I just need to understand that to change the copper from 1 gig to 10 gig , its the two port license , if anything they two port will be shared and I will run mlag at the other end between two existing X670V-48T units already in teh core ..
So my question is still teh same , with the 2 port licence this will upgrade the 2 copper from 1G
 to 10G
Photo of Peter
Peter
  • 1,018 Points 1k badge 2x thumb
The 10G Dual Lic ist alway for the shared 10G ports, if the device has 10G Copper (not all X440G2 10G devices have shared copper ports).
@Dana & Alexandr - Rod doesn't write that he want to stack...
btw... 10G Stacking via copper (RJ45) is not supported...
Photo of Alexandr P
As I understand.
When you use dual-upgrade-license - it's for ports 51-52.
(because if you use Stack you don't need 4-upgrade-license)
So to use 10GBase-T you need dual-upgrade.
Thank you!
Rod Robertson
Hi all , I do not want to stack , just upgrade the copper ports too 10G ( X440-G2-48P-10GE4) Part number 16535
