X440 G2 Stacking with 10GBASE-CR SFP+ 1m
  • Question
  • Updated 2 years ago
  • Answered
short an quik:
Is it possible to Stack 2 X440 G2 48p 10GE4 with 10GBASE-CR SFP+ 1m Cable?
Thank you in advance :)
Photo of Mareen
Mareen
  • 364 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Philipp Tittmann
Philipp Tittmann
  • 774 Points 500 badge 2x thumb
yes but you will need at least two cables. The EXOS stack needs to be an ring topology
Hope this helps
Regards
(Edited)
Photo of Mareen
Mareen
Hi Phillip,
Photo of Muhammad Tariq
Muhammad Tariq, Employee
  • 220 Points 100 badge 2x thumb
Yes it would work! Please make sure you use Ports 49 and 50 when stacking X440-G2-48p-10GE4 switches.
Please also see the below article:
https://gtacknowledge.extremenetworks.com/articles/Q_A/Which-ports-are-used-when-stacking-X440-G2-48...
Kind regards,
Muhammad Tariq
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Mareen  you can use one cable as we do support a daisy-chain design but it is not recommended as it can get you into some trouble with a dual master if the ring fails.  So I agree with Phillip that you should use two.
P
