X440-G2 will not forward mac address info , over shared 10gig port , to X670 running mlag.
  • Question
  • Updated 1 year ago
  • Answered
I have a very basic configuration , from an X440-g2 licenced to use the 10Gig ports ( shared ) connected to 2 x 670 units running mlag , the x440 share is basic L2 and is static ( no lacp )
So the voice vlan is tagged at both the x440 and  the 2 X670 .. I can see the mac address on the x440 , I do not see the mac address on the x670's , the voice ports are tagged for Avaya phones . Disable one side of the mlag uplink . With a static ipaddress set on the laptop I can ping the local switch IP address ( in same vlan ) I cannot ping the ( virtual )  DFG on the x670 running vrrp . , or its physical address. The X440 has been rebooted .
Code :
X670 running 15.5.4.2
X440 G2 running 21.1.3.7-patch1-4
Photo of Rod Robertson
Rod Robertson
  • 2,344 Points 2k badge 2x thumb
Posted 1 year ago
Photo of Balaji
Balaji, Employee
  • 776 Points 500 badge 2x thumb
Rod,
Please provide the configurations from the x440 and the 670s.
Rod Robertson
***************************** WARNING ****************************
If you are not authorised to access this system exit immediately.
Unauthorised access to this system is forbidden by company
policies, national, and international laws.
Unauthorised users are subject to criminal and civil penalties as
well as company initiated disciplinary proceedings.
By entry into this system you acknowledge that you are authorised
to access it and have the level of privilege at which you
subsequently operate on this system
ExtremeXOS
Copyright (C) 1996-2016 Extreme Networks. All rights reserved.
This product is protected by one or more US patents listed at http://www.extremenetworks.com/patents along with their foreign counterparts.
configure snmp sysName "xxx"
configure snmp sysLocation "5th Floor, London Office"
configure snmp sysContact "xxxxx, +44 207 xxxxxxxx"
configure sys-recovery-level switch reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-52
configure vr VR-Default add ports 1-52
configure vlan default delete ports 1-52
create qosprofile "QP5"
create qosprofile "QP6"
create vlan "AV"
configure vlan AV tag 11
create vlan "BSTAFF-WLAN"
configure vlan BSTAFF-WLAN tag 27
configure vlan Default tag 4094
create vlan "GUESTWLAN"
configure vlan GUESTWLAN tag 160
create vlan "LONDON_PC"
configure vlan LONDON_PC tag 79
create vlan "LONDON_SERVER"
configure vlan LONDON_SERVER tag 1
create vlan "SWITCH_MANAGE"
configure vlan SWITCH_MANAGE tag 1005
create vlan "VOICE"
configure vlan VOICE tag 19
configure vlan "VOICE" qosprofile QP6
enable diffserv examination port 1
disable flooding all_cast port 1
enable diffserv examination port 2
disable flooding all_cast port 2
enable diffserv examination port 3
disable flooding all_cast port 3
enable diffserv examination port 4
disable flooding all_cast port 4
enable diffserv examination port 5
disable flooding all_cast port 5
enable diffserv examination port 6
disable flooding all_cast port 6
enable diffserv examination port 7
disable flooding all_cast port 7
enable diffserv examination port 8
disable flooding all_cast port 8
enable diffserv examination port 9
disable flooding all_cast port 9
enable diffserv examination port 10
disable flooding all_cast port 10
enable diffserv examination port 11
disable flooding all_cast port 11
enable diffserv examination port 12
disable flooding all_cast port 12
enable diffserv examination port 13
disable flooding all_cast port 13
enable diffserv examination port 14
disable flooding all_cast port 14
enable diffserv examination port 15
disable flooding all_cast port 15
enable diffserv examination port 16
disable flooding all_cast port 16
enable diffserv examination port 17
disable flooding all_cast port 17
enable diffserv examination port 18
disable flooding all_cast port 18
enable diffserv examination port 19
disable flooding all_cast port 19
enable diffserv examination port 20
disable flooding all_cast port 20
enable diffserv examination port 21
disable flooding all_cast port 21
enable diffserv examination port 22
disable flooding all_cast port 22
enable diffserv examination port 23
disable flooding all_cast port 23
enable diffserv examination port 24
disable flooding all_cast port 24
enable diffserv examination port 25
disable flooding all_cast port 25
enable diffserv examination port 26
disable flooding all_cast port 26
enable diffserv examination port 27
disable flooding all_cast port 27
enable diffserv examination port 28
disable flooding all_cast port 28
enable diffserv examination port 29
disable flooding all_cast port 29
enable diffserv examination port 30
disable flooding all_cast port 30
enable diffserv examination port 31
disable flooding all_cast port 31
enable diffserv examination port 32
disable flooding all_cast port 32
enable diffserv examination port 33
disable flooding all_cast port 33
enable diffserv examination port 34
disable flooding all_cast port 34
configure ports 34 auto on speed 100 duplex full
enable diffserv examination port 35
disable flooding all_cast port 35
enable diffserv examination port 36
disable flooding all_cast port 36
configure ports 36 auto on speed 100 duplex full
enable diffserv examination port 37
disable flooding all_cast port 37
enable diffserv examination port 38
disable flooding all_cast port 38
enable diffserv examination port 39
disable flooding all_cast port 39
enable diffserv examination port 40
disable flooding all_cast port 40
enable diffserv examination port 41
disable flooding all_cast port 41
enable diffserv examination port 42
disable flooding all_cast port 42
enable diffserv examination port 43
disable flooding all_cast port 43
enable diffserv examination port 44
disable flooding all_cast port 44
enable diffserv examination port 45
disable flooding all_cast port 45
enable diffserv examination port 46
disable flooding all_cast port 46
enable diffserv examination port 47
disable flooding all_cast port 47
enable diffserv examination port 48
disable flooding all_cast port 48
enable diffserv examination port 49
disable flooding all_cast port 49
enable diffserv examination port 50
disable flooding all_cast port 50
enable diffserv examination port 51
disable flooding all_cast port 51
enable diffserv examination port 52
disable flooding all_cast port 52
enable sharing 51 grouping 51-52 algorithm address-based L2
configure vlan AV add ports 51 tagged
configure vlan BSTAFF-WLAN add ports 51 tagged
configure vlan GUESTWLAN add ports 51 tagged
configure vlan LONDON_PC add ports 51 tagged
configure vlan LONDON_SERVER add ports 51 tagged
configure vlan SWITCH_MANAGE add ports 51 tagged
configure vlan VOICE add ports 10,12,14,16,18,20,22,24,26,28,30,32,34,36,38,40,42,44,51 tagged
configure vlan VOICE add ports 8 untagged
configure vlan Mgmt ipaddress 10.96.0.200 255.255.255.0
configure vlan SWITCH_MANAGE ipaddress 10.26.15.xxx 255.255.255.0
configure qosprofile QP5 maxbuffer 100 weight 1
configure qosprofile QP6 maxbuffer 100 weight 1
configure qosprofile QP5 minbw 0 maxbw 100 ports 1
configure qosprofile QP6 minbw 0 maxbw 100 ports 1
configure qosprofile QP5 minbw 0 maxbw 100 ports 2
configure qosprofile QP6 minbw 0 maxbw 100 ports 2
configure qosprofile QP5 minbw 0 maxbw 100 ports 3
configure qosprofile QP6 minbw 0 maxbw 100 ports 3
configure qosprofile QP5 minbw 0 maxbw 100 ports 4
configure qosprofile QP6 minbw 0 maxbw 100 ports 4
configure qosprofile QP5 minbw 0 maxbw 100 ports 5
configure qosprofile QP6 minbw 0 maxbw 100 ports 5
configure qosprofile QP5 minbw 0 maxbw 100 ports 6
configure qosprofile QP6 minbw 0 maxbw 100 ports 6
configure qosprofile QP5 minbw 0 maxbw 100 ports 7
configure qosprofile QP6 minbw 0 maxbw 100 ports 7
configure qosprofile QP5 minbw 0 maxbw 100 ports 8
configure qosprofile QP6 minbw 0 maxbw 100 ports 8
configure qosprofile QP5 minbw 0 maxbw 100 ports 9
configure qosprofile QP6 minbw 0 maxbw 100 ports 9
configure qosprofile QP5 minbw 0 maxbw 100 ports 10
configure qosprofile QP6 minbw 0 maxbw 100 ports 10
configure qosprofile QP5 minbw 0 maxbw 100 ports 11
configure qosprofile QP6 minbw 0 maxbw 100 ports 11
configure qosprofile QP5 minbw 0 maxbw 100 ports 12
configure qosprofile QP6 minbw 0 maxbw 100 ports 12
configure qosprofile QP5 minbw 0 maxbw 100 ports 13
configure qosprofile QP6 minbw 0 maxbw 100 ports 13
configure qosprofile QP5 minbw 0 maxbw 100 ports 14
configure qosprofile QP6 minbw 0 maxbw 100 ports 14
configure qosprofile QP5 minbw 0 maxbw 100 ports 15
configure qosprofile QP6 minbw 0 maxbw 100 ports 15
configure qosprofile QP5 minbw 0 maxbw 100 ports 16
configure qosprofile QP6 minbw 0 maxbw 100 ports 16
configure qosprofile QP5 minbw 0 maxbw 100 ports 17
configure qosprofile QP6 minbw 0 maxbw 100 ports 17
configure qosprofile QP5 minbw 0 maxbw 100 ports 18
configure qosprofile QP6 minbw 0 maxbw 100 ports 18
configure qosprofile QP5 minbw 0 maxbw 100 ports 19
configure qosprofile QP6 minbw 0 maxbw 100 ports 19
configure qosprofile QP5 minbw 0 maxbw 100 ports 20
configure qosprofile QP6 minbw 0 maxbw 100 ports 20
configure qosprofile QP5 minbw 0 maxbw 100 ports 21
configure qosprofile QP6 minbw 0 maxbw 100 ports 21
configure qosprofile QP5 minbw 0 maxbw 100 ports 22
configure qosprofile QP6 minbw 0 maxbw 100 ports 22
configure qosprofile QP5 minbw 0 maxbw 100 ports 23
configure qosprofile QP6 minbw 0 maxbw 100 ports 23
configure qosprofile QP5 minbw 0 maxbw 100 ports 24
configure qosprofile QP6 minbw 0 maxbw 100 ports 24
configure qosprofile QP5 minbw 0 maxbw 100 ports 25
configure qosprofile QP6 minbw 0 maxbw 100 ports 25
configure qosprofile QP5 minbw 0 maxbw 100 ports 26
configure qosprofile QP6 minbw 0 maxbw 100 ports 26
configure qosprofile QP5 minbw 0 maxbw 100 ports 27
configure qosprofile QP6 minbw 0 maxbw 100 ports 27
configure qosprofile QP5 minbw 0 maxbw 100 ports 28
configure qosprofile QP6 minbw 0 maxbw 100 ports 28
configure qosprofile QP5 minbw 0 maxbw 100 ports 29
configure qosprofile QP6 minbw 0 maxbw 100 ports 29
configure qosprofile QP5 minbw 0 maxbw 100 ports 30
configure qosprofile QP6 minbw 0 maxbw 100 ports 30
configure qosprofile QP5 minbw 0 maxbw 100 ports 31
configure qosprofile QP6 minbw 0 maxbw 100 ports 31
configure qosprofile QP5 minbw 0 maxbw 100 ports 32
configure qosprofile QP6 minbw 0 maxbw 100 ports 32
configure qosprofile QP5 minbw 0 maxbw 100 ports 33
configure qosprofile QP6 minbw 0 maxbw 100 ports 33
configure qosprofile QP5 minbw 0 maxbw 100 ports 34
configure qosprofile QP6 minbw 0 maxbw 100 ports 34
configure qosprofile QP5 minbw 0 maxbw 100 ports 35
configure qosprofile QP6 minbw 0 maxbw 100 ports 35
configure qosprofile QP5 minbw 0 maxbw 100 ports 36
configure qosprofile QP6 minbw 0 maxbw 100 ports 36
configure qosprofile QP5 minbw 0 maxbw 100 ports 37
configure qosprofile QP6 minbw 0 maxbw 100 ports 37
configure qosprofile QP5 minbw 0 maxbw 100 ports 38
configure qosprofile QP6 minbw 0 maxbw 100 ports 38
configure qosprofile QP5 minbw 0 maxbw 100 ports 39
configure qosprofile QP6 minbw 0 maxbw 100 ports 39
configure qosprofile QP5 minbw 0 maxbw 100 ports 40
configure qosprofile QP6 minbw 0 maxbw 100 ports 40
configure qosprofile QP5 minbw 0 maxbw 100 ports 41
configure qosprofile QP6 minbw 0 maxbw 100 ports 41
configure qosprofile QP5 minbw 0 maxbw 100 ports 42
configure qosprofile QP6 minbw 0 maxbw 100 ports 42
configure qosprofile QP5 minbw 0 maxbw 100 ports 43
configure qosprofile QP6 minbw 0 maxbw 100 ports 43
configure qosprofile QP5 minbw 0 maxbw 100 ports 44
configure qosprofile QP6 minbw 0 maxbw 100 ports 44
configure qosprofile QP5 minbw 0 maxbw 100 ports 45
configure qosprofile QP6 minbw 0 maxbw 100 ports 45
configure qosprofile QP5 minbw 0 maxbw 100 ports 46
configure qosprofile QP6 minbw 0 maxbw 100 ports 46
configure qosprofile QP5 minbw 0 maxbw 100 ports 47
configure qosprofile QP6 minbw 0 maxbw 100 ports 47
configure qosprofile QP5 minbw 0 maxbw 100 ports 48
configure qosprofile QP6 minbw 0 maxbw 100 ports 48
configure qosprofile QP5 minbw 0 maxbw 100 ports 49
configure qosprofile QP6 minbw 0 maxbw 100 ports 49
configure qosprofile QP5 minbw 0 maxbw 100 ports 50
configure qosprofile QP6 minbw 0 maxbw 100 ports 50
configure qosprofile QP5 minbw 0 maxbw 100 ports 51
configure qosprofile QP6 minbw 0 maxbw 100 ports 51
configure dot1p type 5 qosprofile QP6
configure diffserv examination code-point 34 qosprofile QP5
configure diffserv examination code-point 46 qosprofile QP6
configure diffserv replacement priority 5 code-point 46
# Module mcmgr configuration.
# Module fdb configuration.
# Module rtmgr configuration.
configure iproute add default 10.26.15.1
# Module policy configuration.
# Module aaa configuration.
create account admin xx encrypted "w57y0q$/HLv6rjSjS9hYMN6veT4U1"
create account admin xxxx encrypted "4dL2rE$Xustzw82CzU/ewVzxcZ/U/"
# Module acl configuration.
configure access-list zone SYSTEM application NetLogin application-priority 4
configure access-list zone SYSTEM application HealthCheckLAG application-priority 5
configure access-list zone SYSTEM application IdentityManager application-priority 6
configure access-list zone SYSTEM application VMTracking application-priority 7
configure access-list zone SYSTEM application PolicyManager application-priority 8
configure access-list zone SYSTEM application ESVT application-priority 9
# Module bfd configuration.
# Module cfgmgr configuration.
# Module dosprotect configuration.
# Module dot1ag configuration.
# Module eaps configuration.
# Module edp configuration.
configure cdp device-id system-mac
# Module elrp configuration.
# Module ems configuration.
# Module epm configuration.
# Module erps configuration.
# Module esrp configuration.
# Module ethoam configuration.
# Module etmon configuration.
# Module exsshd configuration.
enable ssh2
# Module hal configuration.
# Module idMgr configuration.
# Module ipSecurity configuration.
# Module ipfix configuration.
# Module lldp configuration.
configure lldp port 10 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 12 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 14 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 16 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 18 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 20 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 22 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 24 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 26 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 28 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 30 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 32 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 34 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 36 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 38 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 40 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 42 advertise vendor-specific dot1 vlan-name vlan VOICE
configure lldp port 44 advertise vendor-specific dot1 vlan-name vlan VOICE
# Module mrp configuration.
# Module msdp configuration.
# Module netLogin configuration.
# Module netTools configuration.
configure dns-client add name-server 10.26.80.81 vr VR-Default
configure dns-client add name-server 10.26.80.82 vr VR-Default
configure dns-client add domain-suffix bridcap.com
configure sntp-client primary 10.26.80.81 vr VR-Default
configure sntp-client update-interval 1800
enable sntp-client
# Module ntp configuration.
# Module poe configuration.
# Module rip configuration.
# Module ripng configuration.
# Module snmpMaster configuration.
configure snmpv3 delete mib-view "defaultUserView" subtree 1.0
configure snmpv3 delete mib-view "defaultAdminView" subtree 1.0
configure snmpv3 delete mib-view "defaultNotifyView" subtree 1.0
configure snmpv3 delete community "private"
disable snmp access
disable snmpv3 default-group
disable snmpv3 default-user
# Module stp configuration.
# Module techSupport configuration.
enable tech-support collector
# Module telnetd configuration.
disable telnet
# Module tftpd configuration.
# Module thttpd configuration.
disable web http
enable web https
# Module twamp configuration.
# Module vmt configuration.
# Module vsm configuration.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,886 Points 10k badge 2x thumb
the "disable flooding all_cast" commands seem problematic. Please see Switch will not forward traffic with default configuration.
Erik
Rod Robertson
I have asked for the core switch config, this is a basic mlag config using port 51 and 52 shared as the uplink to port 25 on each of the core x670 units.
Rod Robertson
Erik looks like this has worked , the document implies that this is fixed in 21.1.1.4 code , while I am running 21.1.3.7 so the anomaly is still there and no fixed.
Hi Rod,
good to know that this solved your problem. :-)
Please consider opening a case for this issue so that it can be fixed in 21.1.3.7 and hopefully other versions as well.
Thanks,
Erik
Hi Rod,
did you check that all the VLANs are added to the ISC link between the MLAG peers?
You might find the GTAC Knowledge article How to perform MLAG troubleshooting helpful.
Thanks,
Erik
