X440-24t-10G reporting temperature warnings/errors
  • Question
  • Updated 4 years ago
Create Date: Sep 19 2013 11:08AM
I had a similar problem with X440-24t switches, but problem disapereed  after upgrading to XOS  15.3.2.11 patch1-2.
I got 2 X440-24t-10G switches also running 15.3.2.11patch1-2. Both switches are reporting temperature warning/error messages:
09/19/2013 12:38:09.88 Environment warning reported.  Setting Environment LED color to Amber
09/19/2013 12:38:09.88 Switch: Temperature (69 C) is reaching maximum limit (70 Celsius). (X440-24t-10G,
09/19/2013 12:28:39.88 No Environment warnings present.  Setting Environment LED color back to Green (normal)
09/19/2013 12:28:39.88 Switch: Temperature (67 C) is back to operating range (10 to 69 Celsius). (X440-24t-10G
09/19/2013 12:05:09.91 Switch: Temperature (70 C) above operating range (0 to 70 Celsius) (X440-24t-10G
09/19/2013 11:57:39.91 Environment warning reported.  Setting Environment LED color to Amber
09/19/2013 11:57:39.91 Switch: Temperature (69 C) is reaching maximum limit (70 Celsius). (X440-24t-10G
09/19/2013 11:49:11.65 No Environment warnings present.  Setting Environment LED color back to Green (normal)
09/19/2013 11:49:11.65 Switch: Temperature (67 C) is back to operating range (10 to 69 Celsius). (X440-24t-10G
09/19/2013 11:36:41.67 Switch: Temperature (70 C) above operating range (0 to 70 Celsius) (X440-24t-10G
09/19/2013 11:28:41.67 Environment warning reported.  Setting Environment LED color to Amber
09/19/2013 11:28:41.67 Switch: Temperature (69 C) is reaching maximum limit (70 Celsius). (X440-24t-10G
09/19/2013 11:19:11.64 No Environment warnings present.  Setting Environment LED color back to Green (normal)
09/19/2013 11:19:11.64 Switch: Temperature (67 C) is back to operating range (10 to 69 Celsius). (X440-24t-10G
09/19/2013 10:58:11.66 Switch: Temperature (70 C) above operating range (0 to 70 Celsius) (X440-24t-10G
09/19/2013 10:48:43.43 Environment warning reported.  Setting Environment LED color to Amber
09/19/2013 10:48:43.43 Switch: Temperature (69 C) is reaching maximum limit (70 Celsius). (X440-24t-10G
09/19/2013 10:39:13.40 No Environment warnings present.  Setting Environment LED color back to Green (normal)
09/19/2013 10:39:13.40 Switch: Temperature (67 C) is back to operating range (10 to 69 Celsius). (X440-24t-10G
09/19/2013 10:13:13.40 Switch: Temperature (70 C) above operating range (0 to 70 Celsius) (X440-24t-10G
09/19/2013 10:04:13.44 Environment warning reported.  Setting Environment LED color to Amber
09/19/2013 10:04:13.43 Switch: Temperature (69 C) is reaching maximum limit (70 Celsius). (X440-24t-10G
09/19/2013 09:55:45.19 No Environment warnings present.  Setting Environment LED color back to Green (normal)
09/19/2013 09:55:45.19 Switch: Temperature (67 C) is back to operating range (10 to 69 Celsius). (X440-24t-10G
09/19/2013 09:24:45.17 Switch: Temperature (70 C) above operating range (0 to 70 Celsius) (X440-24t-10G
09/19/2013 09:16:15.18 Environment warning reported.  Setting Environment LED color to Amber
09/19/2013 09:16:15.18 Switch: Temperature (69 C) is reaching maximum limit (70 Celsius). (X440-24t-10G
Temperature seems to be ok. 41 Celsius.
Any ideas how to fix this ?
/brors
(from Brors)
Photo of EtherNation User
EtherNation User, Official Rep
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Sep 27 2013 12:17PM
Hello Brors
Can you tell e if the fans are on with this high temp reading?
Thanks
P
(from Paul_Russo)
Create Date: Sep 30 2013 11:34AM
SW001.5 # show fans
FanTray information:
 State:                  Operational
 NumFan:                 2
 Fan-1:                  Operational at 0 RPM
 Fan-2:                  Operational at 0 RPM
SW001.6 # show temperature
Field Replaceable Units               Temp (C)   Status   Min  Normal   Max
Switch         : X440-24t-10G           44.50    Normal   -10    0-48  55
No fans are active and temperature seems oki.
/brors
(from Brors)
