x440 trial license and EAPS Multi-Ring functionality
  • Question
  • Updated 4 years ago
Hello extreme guys
Is there a command to activate a trial license on a X440 Switch (Sw-Version 15.4.x)? In older versions there was a command, but when I try this on the X440 it doesn't function.
Another question is it on a X440 available to create a multi-ring EAPS with advance edge license? (core isn't available on X440..)
Thank you in advance for your reply.
Photo of Fed Ex
Fed Ex
  • 190 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
Isn't "debug epm enable trial-license" command working on EXOS 15.4? What error messages it is giving?
multiple physical rings is supported on X440 but not the common link.
Photo of Ed Kott
Ed Kott
  • 70 Points
I've found that you used to be able to type "debug epm enable trial" but now with XOS the complete command "debug epm enable trial-license" is necessary.  The same goes for "debug epm clear trial-license".
Photo of Stephane Grosjean
Stephane Grosjean
  • 762 Points 500 badge 2x thumb
Yes, since 15.3.2 you have to type debug commands entirely.
