x450-G2 won't boot after enabling stacking on master
Alan_Santoro
Hey folks!
I'm working on a stack of (3) X450G2-48p-10G4 to replace our old X350 user stack. The new switches have 16.1.0.18 on them from the factory. I enabled stacking and the switches rebooted, but (what should have been) the number 2 switch did not come back up. Consoled into it and found it stuck at:
Copyright 2014 Extreme Networks, Inc.
Starting CRC of Default image
Using Default image ...
I attempted to reboot and get into bootloader a few times, but was not successful. Has anyone seen this before?
2 REPLIES 2
Drew_C
Valued Contributor III
Hi Alan, Can you let us know if this issue has been resolved?
Stephane_Grosj1
first of all you should have upgraded, the prompt must have been telling you that: this exos image is not a GA one.
If you cannot go further than that, maybe you can try an upgrade through bootloader. Can you access it? reboot and from console keep pressing the space bar. Don't wait for the message to appear, you might miss it. Try also without stacking cables connected.
