X450a compatible stacking cables
  • Question
  • Updated 3 years ago
  • Answered
I just got these for my lab and now I need correct stacking cables. The manuals talk about model 16106 0.5 meter cable with manufacturing part number 900296-00/10/11.
Looking online I see lots of different shipping part numbers and cable tags with this same model number, for example:
900296-10-03, 900296-10-04, 900296-00-03, 250084-00 Rev. 02, 250076-00 Rev. 03.
Are these all interchangeable, or is there a difference?
Photo of nixcraft
nixcraft
  • 176 Points 100 badge 2x thumb
  • excited
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,226 Points 50k badge 2x thumb
I always check the datasheet as it includes all the correct numbers and explanation so here a link..
http://tech.extremenetworks.com/libraries/products/DSSUMX450a_1243.pdf
From the last page....
16106 Stacking Cable, 0.5M SummitStack/UniStackTM Stacking Cable, 0.5M
16107 Stacking Cable, 1.5M SummitStack/UniStack Stacking Cable, 1.5M
16108 Stacking Cable, 3.0M SummitStack/UniStack Stacking Cable, 3.0M
16105 Stacking Cable, 5.0M4 SummitStack Stacking Cable, 5.0M
-Ron
Photo of nixcraft
nixcraft
Thanks, I looked at that and the installation guide. I just wasn't sure because there seems to be different revisions of the cables. Should I just trust that it works if the model number is correct, even if the shipping part number and tag on the cable vary?
Photo of Drew C.
Drew C., Community Manager
  • 40,694 Points 20k badge 2x thumb
Hello,
You shouldn't need to worry about the "900 number."  The last two digits of that number are the Revision Number.
From what I can tell in our internal databases, it looks like the revisions were changed to signify different levels of RoHS compliance and/or different manufacturers.  The actual 0.5M cable is the same.
The "200 number" is just another instance of the original part, and shouldn't matter.
As long as the cable is identified by the 5-digit part numbers Ron listed, you shouldn't have any trouble. Just make sure you're doing your due diligence in choosing a vendor.  If there's ever any question, you can always check in with your SE or Account Manager.
Photo of nixcraft
nixcraft
Thanks, that's very helpful!
