x460-48p error 5: fan failing / operational again over and over in the log
  • 3
  • Problem
  • Updated 3 years ago
  • Solved
Hello,
Has anyone seen these types of errors? We are seeing these in the log for both switches in a 2-switch stack. Is it really possible that 2 switches are having similar fan problems at the same time?
05/15/2015 10:39:17.80 Slot-2: Slot-2, Error 5: Fan #4 in slot 2 operational. Rpm 3485 is back to operating range (from 2320 to 8050 rpm).
05/15/2015 10:39:17.79 Slot-2: Slot-2, Error 5: Fan #3 in slot 2 operational. Rpm 3343 is back to operating range (from 2320 to 8050 rpm).
05/15/2015 10:39:17.77 Slot-2: Slot-2, Error 5: Fan #2 in slot 2 operational. Rpm 7336 is back to operating range (from 5120 to 16100 rpm).
05/15/2015 10:38:47.80 Slot-2: Slot-2, Error 5: Fan #1 in slot 2 operational. Rpm 15855 is back to operating range (from 5120 to 16100 rpm)
05/15/2015 10:38:18.65 Slot-1: Slot-1, Error 5: Fan #2 in slot 1 operational. Rpm 7228 is back to operating range (from 5120 to 16100 rpm).
05/15/2015 10:38:18.65 Slot-1: Slot-1, Error 5: Fan #1 in slot 1 operational. Rpm 7561 is back to operating range (from 5120 to 16100 rpm).
05/15/2015 10:38:17.78 Slot-2: Slot-2, Error 4: Fan #4 in slot 2 failed. Rpm 8057 is out of operating range (from 2320 to 8050 rpm). (X460-
05/15/2015 10:38:17.78 Slot-2: Slot-2, Error 4: Fan #3 in slot 2 failed. Rpm 8057 is out of operating range (from 2320 to 8050 rpm). (X460-
05/15/2015 10:38:17.77 Slot-2: Slot-2, Error 4: Fan #2 in slot 2 failed. Rpm 16384 is out of operating range (from 5120 to 16100 rpm). (X46
Any suggestions would be helpful.
Thanks,
Stan
Photo of Stanley Riley Jr.
Stanley Riley Jr.
  • 950 Points 500 badge 2x thumb
Posted 4 years ago
  • 3
Photo of Hernandez, Joshua
Hernandez, Joshua, Employee
  • 1,564 Points 1k badge 2x thumb
Stanley,
What is the physical status of the fan when the failure messages are occurring?  What is the status of the fan LED?  What version of EXOS?  I would also suggest reaching out to GTAC so we can troubleshoot further and identify the issue.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,710 Points 20k badge 2x thumb
Take a look at the following article to see if it addresses it....
 http://gtacknowledge.extremenetworks.com/articles/Solution/Summit-X460-Fan-Failure
Stanley Riley Jr.
Joshua,
I'm not physically at the location, so I'm having my site lead check the LED.
The EXOS version is 12.5.4.5 patch 1-4.
Stanley,
Have these fans been recently pulled and reinserted?  Were there any recent changes? Also please note that the recommended release for a Summit X460 is 15.5.3.4-patch1-5.
Stanley Riley Jr.
Joshua,
No recent changes and the fans were not touched to my knowledge.
Doug,
Here is the output of my debug command:
=======Environmental Data========
Fan Slot: 1 State OPERATIONAL
Fan Part Info:
Name:
SerialNum:
PartNum:
Revision: 0.0
Flags: 0
FailureCode: 0
PowerOnDate: Wed Dec 31 19:00:00 1969
Fimware Rev: BuildTag:
gridId: 0 Number of voltage line to monitor: 1
Volt: 12.00V Watts: 5.00W
Fan#0: State: FAILED Location:
Fan#1: State: FAILED Location:
Fan#2: State: OPERATIONAL Location:
Fan#3: State: OPERATIONAL Location:
Odometer: not supported
Temperature: 0 Celsius
RpmLow 3500 RpmHigh 15500
Fan1: 7561 rpm
Failed 0 FailedCount 0
Fan2: 7336 rpm
Fan3: 3171 rpm
Fan4: 3110 rpm
Fan control period: 0 msec
Desired temperature: 30
Fan Power Level: 0 errorSum: 0 biasGain: 0
Fan Slot: 2 State OPERATIONAL
Fan Part Info:
Name:
SerialNum:
PartNum:
Revision: 0.0
Flags: 0
FailureCode: 0
Fan#0: State: OPERATIONAL Location:
Fan#2: State: FAILED Location:
Fan#3: State: FAILED Location:
Fan1: 16384 rpm
Fan2: 16384 rpm
Fan3: 8057 rpm
Fan4: 7927 rpm
Fan Slot: 3 State EMPTY
Stanley Riley Jr.
Doug,
Also, sh fan shows that they are operational:
FanTray-1 information:
State: Operational
NumFan: 4
Fan-1: Operational at 7561 RPM
Fan-2: Operational at 7447 RPM
Fan-3: Operational at 3212 RPM
Fan-4: Operational at 3072 RPM
FanTray-2 information:
State: Operational
NumFan: 4
Fan-1: Operational at 7123 RPM
Fan-2: Operational at 7561 RPM
Fan-3: Operational at 3321 RPM
Fan-4: Operational at 3461 RPM
FanTray-3 information:
State: Empty
FanTray-4 information:
State: Empty
FanTray-5 information:
State: Empty
FanTray-6 information:
State: Empty
FanTray-7 information:
State: Empty
FanTray-8 information:
Stanley,
Thank you for that information.  I would suggest calling into GTAC so we can open a service request and troubleshoot the issue further and determine a resolution.
Stanley Riley Jr.
ok, will do. Thank you very much for your time today. :)
Actually, one more question, are the fans in the x460 replaceable, or does the whole switch need to be replaced? I'm trying to plan my next steps.
Stanley,
The Summit X460 fans are modular and can be replaced.
Stanley Riley Jr.
Whew, no rebuilding of the stack then. That's good for me. ;)
Stanley Riley Jr.
Sorry to bring this up again, but I need to retrieve the fan serial numbers for GTAC. They suggested running sh fan det, but that doesn't show any serial numbers. Is there a different place I can check? Please keep in mind that I'm currently running XOS 12.5.4.5patch1-4. Thanks for any tips.
Stanley Riley Jr.
We got it. It is due to the version of XOS we are running there. We just pulled the fans and took pics of the serials. lol
