X460-48p - Second PSU does not fit?
  • Question
  • Updated 3 years ago
  • Answered
We are trying to figure this problem out with our supplier, but maybe some of you bumped in the same issue. Basically we have 2 x460-48p with the second PSU. Now, there is a tiny piece of metal that sticks out from the first psu to the second psu bay which is preventing us to insert the second psu. That piece of meal is identical on both switches.
Any ideas?
thanks
Photo of Localhost
Localhost
  • 452 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
I am not sure, but I find some of the fit and finish of the "Extreme" products needs some TLC.  Definitely not as well built as the Enterasys stuff.
Photo of Drew C.
Drew C., Community Manager
  • 40,072 Points 20k badge 2x thumb
Can you elaborate?  The issue described here seems to be due to an actual incompatibility rather than a manufacturing tolerance or fitment problem.
(Edited)
Photo of Jeremy
Jeremy, Embassador
I have has several new 460G2 where the fan modules didn't quite fit and I had to "force" them in.  Granted, everything works, but I am use to equipment where almost no effort is required to insert a fan, PSU etc.  I have not always found that to be the case with the purple stuff.
Photo of Jeremy
Jeremy, Embassador
I should also say, a majority of them were fine and had no issues at all.  But we had so many damaged products from the shipper that these devices could have been slightly damaged but not enough to be visible.  Like I said, everything works so it wasn't that big of a deal.
Photo of Drew C.
I vaguely remember hearing something similar to this a while back.  I think this issue has been fixed - probably since your initial receipt of the X460-G2.  I'll send a note to the quality team so they can check into it.
Photo of Localhost
Localhost
that is definitely something weird...it looks it is made on purpose to block the installation of the PSU. Anyway...
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
What is the PN# of the power supply you are trying to install?  The metal piece you are speaking of is only on the non-poe power supply to prevent you from using it in a POE model.  Assuming this is a X460-48P (gen 1) - The part # of the power supply should be - 10931 - 750W - Cannot use the 10930A which is a Non-POE model. What part # is on the label?
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,476 Points 10k badge 2x thumb
As Bill said, this sounds definitely like you have non-PoE PSU that you are trying to insert in a PoE switch (or vice-versa). This cannot work and the switch/PSU have been made in a way to avoid that mistake.
Photo of Localhost
Localhost
thanks heaps. I think it is because it is not POE. We are arranging the replacement
