X460-48t 10GB optical port
  • Question
  • Updated 3 years ago
  • Answered
Hello experts,
I have a basic question regarding summit x460 series switches, I have two x460-48t switches:
48 x 10/100/1000BASE-T (RJ-45)
4 x 100/1000BASE-X (SFP) unpopulated ports
1 x Serial (console port)
1 x 10/100BASE-T out-of-band management port
1 x USB port for external USB flash
taking into consideration this information, is possible to add an additional module to have 10GB optical port(s) available?.
Thanks in advance,
Miguel.
Photo of Miguel
Miguel
  • 142 Points 100 badge 2x thumb
Posted 3 years ago
Photo of EtherMan
EtherMan
  • 606 Points 500 badge 2x thumb
Easy one ... two daughter card options that go into back of switch... Must power switch down to insert ... Need to also look at code rev to make sure the switch has right code for the daughter card...
16117 ... 2 port sfp + card or 16120 4 port sfp + card........ we have had great service with this combo...
Photo of Miguel
Miguel
Thanks Robert!, 16117 is exactly what I am looking for, I have other question , for x460 this expansion cards can be 10GB optical or 1GB optical too?, Thanks!
Photo of EtherMan
EtherMan
Not sure about putting a standard one gig sfp in the port but we have put 10 gig optics and set port to 1000  auto auto to match upstream link on remote sites.... When we upgraded to 10 gig a few months later we were able to upgrade by having to swap only the one side and change port settings which saved a trip and another re-boot of systems to install the card..
Photo of Drew C.
Drew C., Community Manager
  • 39,442 Points 20k badge 2x thumb
The port's negotiation/speed settings may need to be manually configured, but I'm pretty sure a 1G SFP will work in the SFP+ port.  Something we could test in the lab quite easily.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,304 Points 10k badge 2x thumb
I know that I've seen this work in the lab (1G SFP in SFP+ port), but I'm not sure off the top of my head what the optics and switches involved were. It could definitely be tested fairly easily.
(Edited)
