X460-G2-48X "Error while loading Ports: Speed Change is not allowed"
Dennis_K
Hi Guys,
thank you for visiting my Thread. Today we installed two X460-G2-48X as an Stack (Stacking Cable 1,5m) and configured on each Switch 1 Port as a Uplink Port to the Black Diamond Core Switches. (LACP)
But the Link doesn't come up. We rebooted and updated the Firmware to Version: 15.7.2 but nothing changed.
We still get this Error Message in the Log:
07/28/2015 15:33:46.63 Slot-2:
Error while loading "ports": Speed change is not allowed on port 2:52 as it is a trunk member port.
07/28/2015 15:33:46.22 Slot-2: mcmgr cannot write msg_id 5 to MASTER connection 0
We checked the configuration on both sides (X460 and BD)
All ports are configured on the same speed (10G)
Any Idea?
Thank you for your Help!
Dennis
9 REPLIES 9
Dennis_K
Hello Guys,
thank you very much for this information! šŸ™‚
Maybe we should read the Datasheet before we open a new Thread. :-))
Wish you all a great day!
Stephane_Grosj1
10GBASE-CR SFP+ 10m is not supported on the front 10G ports of the x460G2. Check page 12 of the DS for the transceiver support matrix.
Andrew_Maldonad
Dennis,
Regarding the Summit X460G2, the 5 and 10 meter passive cables are only supported on the VIM-2x module. The front panel 10Gb ports are PHYLESS, so the maximum supported DAC length is 3 meters.
-Andrew
Dennis_K
Hello together,
we found the "problem".
My Teammate changed the Cable Medium from Copper to Fiber and the link comes up.
Thats the difference:
before:
"10GBASE-CR SFP+ 10m" -> DONT WORK
after:
ā€ž10GBASE-SR SFP+ā€œ -> WORK
Maybe any one of you know the reason why that one cable work and the other one dont.
If you need some information as well, just scream. ļ™‚
