X460-G2 connecting 10 meter DAC Cable possible ?
  • Question
  • Updated 2 years ago
  • Answered
we want to uplink several X460-G2 switches via 10 meter Copper DAC Cable to a S4.
But it seems not working. Does anybody know if the X460-G2 10Gb optic ports have the needed PHY unit to get 10m Cables runnig ??
Behaviour:
S4 port Link is Up / X460-G2 port stay down - but DAC cable will be recognize correctly.
Switch-1.8 # sh port 52 configuration no-refresh
Port Configuration
Port     Virtual    Port  Link  Auto   Speed      Duplex   Flow  Load   Media
         router     State State Neg  Cfg Actual Cfg Actual Cntrl Master Pri Red
UPL-Core VR-Default  E      R   OFF 10000       FULL                52  SF+_CX10
> indicates Port Display Name truncated past 8 characters
X460G2-48p-10G4 / EXOS 16.1.3.6-patch1-9
Photo of M.Nees
M.Nees, Embassador
  • 9,126 Points 5k badge 2x thumb
Posted 2 years ago
Photo of M.Nees
M.Nees, Embassador
i found an answer in the X460-G2 Datasheet -  it is not possibel!
Section: Transceiver Support Matrix
It will only work within a the optional VIM Module!
Photo of Mel78, CISSP, ECE
Mel78, CISSP, ECE
  • 1,044 Points 1k badge 2x thumb
Yes. Use either max 3m DAC for PHYLESS or go FO SFP+ SR modules.
VIM-2x will definitely support 5m and 10m DAC cable.
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
