x460-g2 swtich failed again and again
anil
is anyone help...i have x460-g2-48p and x440-g2-24p and both are in stacking... but x460 switch failed 4 times,,i rasied request from RMA i got new switch and configured the same, its working for one month then again failed.. this issue happen 4 times with switch 460..still going on...not sure what is the issue..i check the power coming from dedicated UPS...after switch failure only mgmt,fan.p1,p2 led blinking...other port led not blinking..also switch FAN not moving, when i connect this fan on anther switch its working..this issue happen with all four switch same incident...it can possible due to staking, even os version same in both x460 and 440, only port difference,,please help..if any one have an idea..
2 REPLIES 2
Bin
Hi, anil.
There is the article to guide you how to open the case if you need it.
How To Create a Case Through Extreme Support Portal
https://gtacknowledge.extremenetworks.com/articles/How_To/Create-a-Case-via-New-Portal
Best regards,
OscarK
Upgrade to the latest EXOS 22.3 image, check if the problem still happen. If it does, log a case with GTAC,
