X460-G2 VIM-2q : Can this be used with fan-out cables to give 8x10G
  • Question
  • Updated 2 years ago
  • Answered
Hi folks,
Quick question...
Is it possible to use the QSFP VIM-2q ports as 4x 10G ports (as is possible, for example, with the X670's 40G ports) in an X460-G2?
The reason I'm asking is that the X460-G2 datasheet says that the maximum number of 10G ports available on an X460-G2 is 6 (for a -24x switch), but am hoping that I can get an extra 8 using a VIM-2q.
Thanks
Paul.
Photo of Paul Thornton
Paul Thornton
  • 1,424 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,254 Points 10k badge 2x thumb
Hi Paul,
Unfortunately, this is not possible on the X460-G2. Due to the hardware design, the switch is only able to recognize two ports on the VIM, regardless of port speed.
-Brandon
Photo of Donna Rupert
Donna Rupert
  • 240 Points 100 badge 2x thumb
No. I was told that was not supported.
Paul Thornton
Thanks for the confirmation of that, Brandon.  I'll just tell the customer he needs to buy some more X670s :-)
Paul.
Depending on application, the new X620 may also be useful for them.
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,930 Points 5k badge 2x thumb
Yep.  It doesn't have the port buffer of the x670 but it is 10G
Photo of Carsten Buchenau
Carsten Buchenau
  • 942 Points 500 badge 2x thumb
And extremely good in price :-). We are planning to use it as 10G aggregation switch, L2 only, in Wireless infrastructure networks. They do support routing, but that should be looked at carefully as performance might not be enough.
You can do 6 with 4 in the front and with a VIM-2x or VIM-2t for the extra 2.
