X670-G2 with EXOS 21.1.2.14: Establishing SSH session takes too long
  • Question
  • Updated 2 years ago
  • Answered
Establishing a SSH connection with Summit X670-G2, EXOS 21.1.2.14 takes too long.
You have to wait 15-17 seconds, before the prompt is showing.
Generating a new SSH key helps for a short time, but then this problem reoccurs, ~1 week.
We already reinstalled the ssh-module but can't find a solution.
Tried it with PuTTY and SmarTTY, but both SSH-clients are reacting in the same way.
The exsshd-process is in version 6.5.1.69 - cpu and memory are looking good.
Does anyone experienced the same behavior?
Photo of Chacko
Chacko
  • 1,206 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Ty Kolff
Ty Kolff
  • 1,098 Points 1k badge 2x thumb
I have experienced this on not only the x670-G2, but also on x460-G2's running 21.1.2.14.  We ended up downgrading some x460-G2's to 16.1.4.2 patch 1-7 because of some LACP issues, and the SSH connections are fast on that release, although you have to load the SSH module seperately.
They are suppose to be releasing a fix for other SSH issues in 21.1.3 which could be released any day now.
https://community.extremenetworks.com/extreme/topics/exos-version-21-1-3?utm_source=notification&...
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,288 Points 3k badge 2x thumb
Johannes,
A CR# xos0063806  has been opened to address the SSH issue. Our Engineering team has included the fix in EXOS 16.2.2 which is available in our portal.  They are working to include the fixes in EXOS 21.1.3.1 & 22.3.1 which is in-progress.
The temporary work-around is to gracefully restart the exsshd process.
Photo of Chacko
Chacko
Alright, thanks for the feedback.
Then we will try the workaround and wait for the new EXOS release.
Photo of Chacko
Chacko
I haven't mentioned it before, but the workaround works with X670-G2.
Photo of HarrySo
HarrySo
  • 482 Points 250 badge 2x thumb
Hello Guys!
We have the same Problem with our X620-16x switches running summitX-22.1.1.5.xos. A "restart process exsshd" does not help. SSH Login lasts 15-30 seconds
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
As per  the CR which was provided earlier by my colleague,Currently what i see the EXOS 21.1.3 is ready to be released either end of Jan or max by mid feb 2017. Already regression test started on this since 5th jan and no more further issue reported yet.
Coming to path release of 21.1.3 (21.1.3p1 is expected around march 2017)
