x670 ideal operating temperature (stack with x460)
  • Question
  • Updated 2 years ago
  • Answered
Hi community,
I have X670G2-48x-4q and X460G2-48t-G4 (version switches stacked with each other. When i have looked up its 'show temperature output is like that :
-> show temperature
Field Replaceable Units Temp (C) Status Min Normal Max --------------------------------------------------------------------------- Slot-1 : X670G2-48x-4q 74.50 Normal 0 10-100 110 Slot-2 : X460G2-48t-G4 82.28 Normal 0 10-100 110 Slot-3 :
Although status part is normal, I am not sure  the temperature value is normal or not. It could be higher than its operational temperature. In X670 data sheet, operating temperature is between 0 to 45° C  and in x460, 0° C to 50° C.  The cpu usage and fan status is also normal.
 I didn't observe any abnormal log on the switch and  i don't have any information about operating temperature in stacking conditions.
I wonder these temperature values is normal or not in a standard data center.
Photo of Yasar
  • 136 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,364 Points 3k badge 2x thumb
Hi Yasar,
Please find the below article , I hope this will answer your question.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 12,754 Points 10k badge 2x thumb
Hi Yasar,
Just to clarify, the temperature ranges you found in the data sheets are for the first generation X670 and X460. The X670-G2 and X460-G2 switches have a higher maximum operating temperature, as indicated in the CLI output.
