x670v stacking with RP multicast join over backbone
  • Question
  • Updated 1 year ago
  • Answered
At a client we are using 3 stacks with 3x x670v with XOS 15.4.3 configured with native stacking in V160. Between the 3 stacks we use a 40Gb connection (QSP+ with LACP L2).
Each stack makes use of a rendez-vous point.
rendez-vous point configuration lines:
configure pim crp vlan "Local_1" "rp-list1" 30
configure pim cbsr vlan "Local_1"
enable pim
rp-list of the first stack:
entry extreme_rp1 {
	if match any { }
	then {
	nlri 239.1.13.0/24 ;
	nlri 239.1.14.0/24 ;
	nlri 239.1.15.0/24 ;
	nlri 239.1.16.0/24 ;
	nlri 239.249.0.0/24 ;
	nlri 239.255.255.0/24 ;
	nlri 224.2.127.254/32 ;
I have the following questions:
1. Is it correct that a new multicast stream will (for a short period) flow to the master slot (switch) in a stack? If yes, what is the dispatch time period?
2. If a destination join a multicast stream this will (for a short period) flow to the master slot (switch)?  If yes, what is the dispatch time period?
3. If a destination switches a multicast stream this will (for a short period) flow to the master slot (switch)? If yes, what is the dispatch time period?
4. There is much joining/dropping of streams in this setup, with a high number (40+) streams of 3,6Gb. Will this exceed the bandwidth of the backbone within a stack?
Photo of Erwin van Hoof
Erwin van Hoof
  • 344 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,574 Points 10k badge 2x thumb
Hello Erwin,
A stack should function like one so I wouldn't say the stream is flowing to the master. It will come in on the port and VLAN. All of these question should be pretty much instant. The bandwidth utilization is not one we will be able to answer. You can check the port utilization to see the percentage. This percentage is an average over 5 seconds though.
Erwin van Hoof
Hello Patrick,
Thanks for your answer.
But how can I view the utilisation of a stack port?
Patrick Voss, Alum
You can use the command:
"show port stack-port utilization"
Erwin van Hoof
Is there anyone who can confirm that the stream is not flowing to the master when it is initiated or joined.
Thanks in advance.
Photo of OscarK
OscarK, ESE
  • 7,792 Points 5k badge 2x thumb
When a stream is started every slot just look at its tables and see if there is an egress port for that stream. If not the stream is initially send to the CPU so it is aware, but that is just a few packets probably. Then the stream will dropped until an egress port is added to the egress list.
The same when someone joins, the IGMP packet goes to the CPU which then programs the multicast table to add that port to the egress list for the multicast stream after which the stream will be forwarded to that port.
