x670V Stacking Issue
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Jun 17 2013 6:53PM
I am stacking 2 x670V switches for our main core.  Since all ports are 10G sfp we are setting up the stack to use Ethernet ports as alternate stacking ports (Ports 47 and 48).  I setup it up like it said in the concepts guide and it runs nice so far (limited testing for now).  When I ran show ports command to see everything I saw this.  I reran the command with just the last 10 ports on each slot.
* Slot-1 Stack.35 # show ports 1:39-48,2:39-48 no-refresh
Port Summary
Port  Display         VLAN Name          Port  Link  Speed  Duplex
#     String          (or # VLANs)       State State Actual Actual
1:39                                      E     R
1:40                                      E     R
1:41                                      E     R
1:42                                      E     R
1:43                                      E     R
1:44                                      E     R
1:45                                      E     NP
1:46                                      E     NP
1:47                                      E     NP
1:48                                      E     NP
2:39                                      E     R
2:40                                      E     R
2:41                                      E     R
2:42                                      E     R
2:43                                      E     R
2:44                                      E     R
2:45                                      E     NP
2:46                                      E     NP
2:47                                      E     NP
2:48                                      E     NP
   Port State: D-Disabled, E-Enabled
   Link State: A-Active, R-Ready, NP-Port not present, L-Loopback,
               D-ELSM enabled but not up
               d-Ethernet OAM enabled but not up
The last 4 ports on each slot show as NP (not present).  I understand that 47 and 48 would be NP since we are stacking with those two ports, but I don't know why 45 and 46 are, unless the switch has to cannibalize 2 extra ports to stack with Ethernet.
* Slot-1 Stack.35 # show version
Slot-1      : ################## Rev 6.0 BootROM: 2.0.1.6    IMG: 15.3.1.4
Slot-2      : ################## Rev 6.0 BootROM: 2.0.1.6    IMG: 15.3.1.4
Slot-3      :
Slot-4      :
Slot-5      :
Slot-6      :
Slot-7      :
Slot-8      :
Image   : ExtremeXOS version 15.3.1.4 v1531b4 by release-manager
          on Mon Feb 4 19:19:04 EST 2013
BootROM : 2.0.1.6
Diagnostics : 5.10
Has anyone else seen this before?
Thanks!
(from bw447)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Jun 17 2013 10:39PM
What is the output of the show stacking stack-port command?
(from ethernet)
Create Date: Jun 18 2013 12:04PM
Hi ethernet,
Thanks for the reply.
Slot-1 Stack.2 # show stacking stack-ports
Stack Topology is a Ring
Slot Port Select Node MAC Address  Port State  Flags Speed
*1   1    47     00:04:96:6d:65:87 Operational C-      10G
*1   2    48     00:04:96:6d:65:87 Operational CB      10G
 2   1    47     00:04:96:6d:65:6d Operational CB      10G
 2   2    48     00:04:96:6d:65:6d Operational C-      10G
* - Indicates this node
Flags:  (C) Control path is active, (B) Port is Blocked
Slot-1 Stack.2 #
(from bw447)
Create Date: Jun 24 2013 3:19AM
Interesting. I would open a case with TAC just to ensure what you're running into is a normal behavior or not.
(from ethernet)
