x690 40Gbe and 100Gbe ports
  • Question
  • Updated 2 weeks ago
I have a pair of x690 switches.
The last 6 ports is configured with the following template:
configure ports partition-template 2x100G-and-4x40G
I want to use the 40Gbe DAC fan out to four 10Gbe SFP+ ports on the four 40Gbe ports.
I configure port 49 and 53 (40Gbe ports) with the following commands:
configure ports 49 partition 4x10G
configure ports 53 partition 4x10G
I configure port 57 and 61 (100Gbe ports with 40Gbe template applied) with the following commands:
configure ports 57 partition 4x10G
configure ports 61 partition 4x10G
The question I have is will the standard QSFP+ - 4xSFP+ fan-out cbl, 3m (Part Code 10321) work in port 57 and 61? These ports are 10Gb/ 25Gb/ 40Gb/ 50Gb/ 100Gb QSFP28 ports
Thx
Photo of Andre Brits Kannemeyer
  • 5,288 Points 5k badge 2x thumb
Posted 2 weeks ago
Be the first to post a reply!
