X870 Console Prt Baud Rate
Stephen_Elliot1
Contributor
Just a question.
Whatever possessed you to change the baud rate on the X870 console port to 115200?
Every one of the other 2000+ network devices I look after, including all our other Extreme switches use 9600. Which means, each time I connect to our X870s I have to change the baud rate on Putty and remember to flick a really REALLY tiny DIP switch on my Bluetooth serial adapter.
The life of a network engineer is tough enough without these pointless hassles.
/rant over
2 REPLIES 2
Stephen_Elliot1
Contributor
but at least make it configurable?
Drew_C
Valued Contributor III
9600 baud is just so slow though! 
