x870 with 10G ports and 100G ports
  • Question
  • Updated 1 year ago
  • Answered
Can we configure 4*100G ports on x870 and use the other ports as 10G ports ? We need to have a switch supporting 10G ports and 100G ports simultaneously
Photo of Sonnic
Sonnic
  • 110 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,886 Points 10k badge 2x thumb
yes, you can configure all ports on the X870 to work as 4*10G:
X870-32c – Spine switch that flexibly supports up to 32 x 100Gb ports, up to 64 x 50Gb ports, up to 128 x 25Gb ports, up to 32 x 40Gb ports, or up to 128 x 10Gb ports via its 32 x QSFP28 interfaces
If you need just 4 ports with 100G, you can use the less expensive X870-96x-8c:
X870-96x-8c – High density leaf switch that supports 96 x 10Gb ports (on 24 x QSFP28 interfaces) and has 8 additional QSFP28 ports to support 10Gb, 25Gb, 40Gb, 50Gb or 100Gb data rates
Thanks,
Erik
Photo of Sonnic
Sonnic
Thanks Erik,
In fact I need some ports to run at 100G and other ones to run at 40G simultaneously, and others to work at 10G in one x870 node. Is that possible ? Which model to use -32c or -96x ?
For full flexibility you need the -32c. The -96x-8c is only the answer for your original question of 4*100G and the other ports at 10G. It provides 96*10G and 8 flexible ports (4*10G/4*25G/40G/2*50G/100G).
Photo of Sonnic
Sonnic
Thanks again: in that cas I will use -32c platform to mix 40G, 100G and (probably byt not sure) 10G ports simultaneously.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,254 Points 10k badge 2x thumb
There's also the possibility of using the X870-96x-8c and purchasing port-speed licenses to allow ports to be used at 100/50/40/25G as needed. The licenses are for 6 port groups.
