XMC TCL script results with 'javax.script.ScriptException: *** Script Error *** null'
  • Problem
  • Updated 2 months ago
  • Solved
  • (Edited)
Hello,
Couple of days ago I was trying to play with XMC scripting capabilities to combine it with VOSS device (VSP4K).
To start with something simple to check if it works, I did a script to enable a port.
CLI script type with exact port specified worked:
enable
configure terminal
interface GigabitEthernet 1/1
no shutdown
exit
I wanted to do the same but with $port variable instead of a fixed port number. I've created a TCL script to be able to do that, and then during the execution XMC did 'configure terminal', I see some standard output about 'CTRL/Z' but then the script didn't continue, there was an error instead:
null
The same if I try a TCL script but with fixed port number instead of $port.
What do I do wrong with that TCL script?
That looks more like a bug but perhaps there's something I don't know.
I've selected a port with $port version obviously. ;)
Regards,
Tomasz
Photo of Tomasz
Tomasz
  • 1,642 Points 1k badge 2x thumb
Posted 2 months ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,824 Points 5k badge 2x thumb
Hi Tomek.
I suggest to check some examples available at GitHub. There are two ways how you can enter the port. Option 1 is to use the input form. Option 2 is to select the port from the list.
Good luck and if you create some useful script feel free to share!
Z.
Photo of Tomasz
Tomasz
  • 1,640 Points 1k badge 2x thumb
Hi Zdenek,
Thank you for the examples. I planned to use the port list approach.
I see there's a lot of things around that small simple $port variable. I'll drill it down to spot the issue on my side.
Apparently, I would like to clone some stuff from EFO for creating VSNs on VSP/ERS devices - unless I get any info that it is already planned for XMC for implementation. ;)
Kind regards,
Tomasz
Create VSNs on VSP/ERS is already available. With Fabric Management introduced in XMC 8.2 you will have much more robust tool.
of course you can create your own scripts/workflows. feel free to share.
(Edited)
Photo of Tomasz
Tomasz
Fabric Management? Sounds EXTREMEly good! :)
We had sneak preview of that in July. It will be demonstrated at the partner conference to the broad audience.
I suggest to start to move to Python from TCL. It is much easier to troubleshoot and much more powerful. Some examples are at GitHub also.
Photo of Tomasz
Tomasz
  • 1,410 Points 1k badge 2x thumb
But does that Python in XMC drive the scripts server-side, or is it a Python that goes to the switch and executes there? If the latter, I agree with you in case of EXOS. For VOSS I didn't see Python support yet...?
Python works the same as TCL there. Executed in XMC and output is sent to the CLI.
