XSR Seems to Freeze
  • Question
  • Updated 2 years ago
  • Answered
I have an enterasys XSR-3150 with firmware :7.6.14.0002.
Sometimes my internet connectivity goes off and I have traced and realized its the router.
I am able to ping and console to verify all my configs and everything seems fine but until I always have to restart the device anytime it happens for connectivity to be restored.
I would appreciate your comments on the possible cause of this and the way forward.
Thanks.
Photo of eberrick
eberrick
  • 280 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Mike D
Mike D, Alum
  • 3,852 Points 3k badge 2x thumb
Hello,
I'd normally be reluctant to comment on behavior correction without a more detailed problem description - configuration, network environment, recent changes etc...
In this case running f/w is vintage 2008.
Release notes between 2008 and the most recent (7.6.17.0001 Nov. 2013) indicate several fixes for resource depletion.
Firmware upgrade is the right next step.
Regards,
Mike
Photo of eberrick
eberrick
Hi Mike, I apologise if I wasn't clear enough in my question. If you could be specific as to the further information needed, I'd be glad to provide.
I suspected the firmware since the current version running is quite old. However extreme doesn't seem to have the firmware for this specific device on its product support page.
Thank you.
Photo of O'Connor, Brendan
O'Connor, Brendan, Employee
  • 350 Points 250 badge 2x thumb
Hi
7.6.17.0001 Firmware is available on the Extranet Portal.  If you are unable to access this, please contact GTAC.
Regards
Brendan
