ZTP+ over WAN Connection
  • Question
  • Updated 2 weeks ago
  • Answered
currently i use ZTP+ for automatic switch update and configuration at customers branch. Ping latency to central XMC is round-about 25ms.
XMC recognize there is a new switch with ZTP+ and because firmware does not equal to reference firmware an update is running. Fine.
Unfortunately this update is done via tftp. So now waiting for 1 hour - tftp is still running ....
Is there a way to speed up?  Related to other switches config backups or firmware updates i would switch over to TCP based SCP.
But how can i do that with ZTP+ process? How can i speed up?
I am pretty sure this issue was already solved by Extreme because all cloud based solutions run into same problem ...
XMC =  // EXOS = X440-G2 -
Photo of M.Nees
M.Nees, Embassador
  • 8,736 Points 5k badge 2x thumb
Posted 2 weeks ago
Photo of Dave Hammers
Dave Hammers, Dir SW Engineering
  • 3,362 Points 3k badge 2x thumb
under XMC control in the Firmware panel.
You can designate a transfer protocol for device families, or individual device types.
Photo of M.Nees
M.Nees, Embassador
Thanks for that worthful advice - i will check that.
I think it would be nice if that parameter would be assigned to a specific site. It makes that more flexibel ...
Photo of Bin
Bin, Employee
  • 5,076 Points 5k badge 2x thumb
Just on the following article for the reference
Does EXOS support transfer of files over SCP
Best regards
