Question
Extreme Management Center - Status only interval
  • 2 August 2021
  • 4 replies
  • 46 views
I need to monitor whether the device is available or not. And when it falls down then get this info ASAP into the XMC.
I wanted to use the Poll Status Only type of device.
But the default polling value is 12 hours and it is not possilbe to set less than 4 hours. If I understand well the device will stay green for 4 hours after it falls down (in the worst case). Due to it is not possible to use this feature to monitor devices and the feature seems unusable.
What is the range of Status Only Poll interval?
And is it possible to monitor state of Status Only device more frequently, e.g. every 5 minutes?
Best regards
Kuba
Userlevel 6
Badge
Hi Kuba,
Would device profile “<ping only>” work for you instead? It’s more frequent but just based on ping.
If you need full availability checks that are more frequent than 4 hrs I’d try to play some dirty tricks such as creating a Python script/process to do that for you and generating a syslog message if something is wrong - but it’s totally besides XMC; XMC could then generate an alarm upon the syslog message reception…
Perhaps issuing a feature request through a local SE would help to convince Extreme to change the status-only interval boundaries.
Hope that helps,
Tomasz
Userlevel 2
What’s the reason you want to use the “Status only poll”? License?
For your scenario you should use one of the three poll groups.
Yes Dany, the primary reason is the License. There is possibility to use many times more Status only devices than the Ping only devices. So the status only would be a great solution for monitoring devices where we need to know just their availability.
But when we know only wheter the device was up 4 hours ago(in case of Status only devices) then it does not make me any sence.
Can you please show me the real use case for using the Status only device type?
Best regards
Kuba
Userlevel 2
I don’t know either what could be a scenario for “Status only poll” if the lowest poll time is 4 hours. Something we should ask Extreme :smile:
Is there a limit about how many “Ping only” devices you can add?
Reply
