Difference between small, medium and large ova files for Managment, Control and Purview
Userlevel 5
Hello,
what are the exact differences between small, medium and large ova installation files for Management, Control and Purview?
I guess there are differences in the mySQL and JBOSS settings. That's all?
Best regards
Stephan
Userlevel 6
Hi Stephan,
That should be a yes, Other factors that drive up the server resource requirements are listed in the below article, I hope this helps!
https://gtacknowledge.extremenetworks.com/articles/Q_A/How-does-Extreme-define-Small-Large-and-Enter...
Userlevel 5
Hi Stephan
If you are using 8.0, please check our release not from Page 15
https://documentation.extremenetworks.com/release_notes/NetSight/9035078-09_ExtremeManagementCenter_...
Extreme Management Center Virtual Engine Requirements
Extreme Access Control Virtual Engine Requirements
Extreme Application Analytics Virtual Engine Requirements
Best regards,
Userlevel 5
Bin wrote:
Hi Stephan
Best regards,
Hello,
For me, it's interesting how you can migrate from an installation for example with the small.ova to medium later (if the customer grow). If only mySQL and JBOSS settings are different. The migration can done according:
http://nms.extremewireless.ca:8080/Clients/help/content/common/health_perf_troubleshooting/ns_perfor...
Or are there other points to take into account?
Best regards
Stephan
Reply
