EMC wireless reports for a group of APs i.e. per building, location
Userlevel 7
Is there a way to generate reports for a certain group of APs (how could I create a group) or use the location/zone information.
I need to generate reoprts for different branch offices and the SSID/WLAN service is the same on all locations so I see no way to do it.
I've created a event report with Connect and I'd see "Area AP38" so I wonder whether I'd create areas to group APs - no idea where the value "Area AP38" - never configured such name.
Any ideas ?
Thx
-Ron
Userlevel 5
Hello Ron,
the only way to create AP-Groups I know, is the NetSight Wireless Manager (see picture below).
But the only report I know for AP-Groups is the standard reports in "Wireless->Oneview->AP Groups". I don't know if you can create own reports for AP groups.
Regards
Stephan
Userlevel 7
SH wrote:
Hello Ron,
Regards
Stephan
Thansk Stephan but I think WM is not longer up to date, my AP3805i-ROW isn't in the WM list.
Another thing is that I never liked or trusted the app - so a no go for me.
Userlevel 5
Hello Ron,
do you have actual infos about how to create ap groups without the "NetSight Wireless Manager"?
Did you open a case?
As you mentioned the WM is not available in the new Extreme Management Releases.
Now the question is, what should users do with AP groups created in front of the update?
If you have no further infos. I will open a GTAC case.
Regards
Stephan
Userlevel 7
Hi Stephan,
no I don't have any new information on the topic and also didn't opened a ticket as I'm too busy with the tickets that I've already open 😞
BR,
Ron
Userlevel 5
Hello Ron,
I opened a ticket according this issue and I got a quick answer:
"...for now and the foreseeable future, access WM via Console will be necessary for creation of AP groups..."
In the moment there is no fix roadmap to replace the Wireless Manager (Java) by a Extreme Managment function.
My 3805 Access Point (without ROW) works fine with the WM (as AP38xx).
As result from my ticket, if your 3805-ROW don't work with WM, you have to create a ticket for this issue.
Regards
Stephan
Userlevel 5
Hello all,
here you will find a video guide: https://www.youtube.com/watch?v=71jhViBD0yk
Regards
Stephan
Reply
