Extreme Management center and Fortigate integration guide?
Any one have a guide in How to integrate the Extreme management center (connect) with the Fortigate?
Userlevel 2
Hello Hossam,
I have the implementation guide for Connect 2.05, which is the latest guide I can find.
It includes instructions for the Fortigate integration.
You can download it from:
https://drive.google.com/file/d/0B5bMj99cONofd19hanpLdUpFQ1U/view?usp=sharing
Cheers,
Ryan
Userlevel 4
Schmotter, Ryan wrote:
Hello Hossam,
Cheers,
Ryan
Hello, Ryan,
Extreme Control is a required component?
Userlevel 2
Hello Hossam,
Cheers,
Ryan
Yes, in order to populate the End System database, you need EAC, which updates the Fortigate. However, if you have EXOS switches and Identity Management enabled, that may populate the ES database without the requirement for EAC, it just has not been tested and is not officially supported.
Userlevel 4
Hello Hossam,
Cheers,
Ryan
Thank you.
I've tested the Identity Management with EXOS switches: it gives some information in CLI about IPs, hostnames and AD users for about 10-15% of switch ports. But the data could not be sent to Netsight.
Reply
