How to display links between switches and C25 controllers on OneView topology maps?
Userlevel 4
Hello, everybody!
The both C25 controllers are on the map and links between cisco and extreme switches are exist.
But there are not links between any switches and C25 controllers. Could it be corrected?
Many thanks in advance,
Ilya
Userlevel 3
Hi Ilya,
Do the C25 AND switches have LLDP (or another discovery protocol such as EDP) enabled?
Regards
Tony
Userlevel 6
AFAIK the C25 does support neither LLDP nor EDP nor CDP nor STP.
AFAIK the feature of drawing link manually in OneView map is on the radar.
regards
Zdenek
Userlevel 4
Hello, gentlemen,
I heard that it impossible for a while to draw links manually in Netsight 6.3.
Thank you.
Reply
