Is it possible to install and activate Extreme Management Center using NMS-BASE-250 License...
Userlevel 1
We have recently purchased the NMS-BASE-250 License for our Network Management. Currently we are using Ridgeline NMS. We are planning to install Netsight 6.3.
Is it possible to install and activate Extreme Management Center using this NMS-BASE-250 License?
Userlevel 6
Hello,
Yes, NMS-BASE-250 can be used to install and run Extreme Management Center. Depending on when the entitlement was redeemed you may need to upgrade it through the portal to use it with version 7 or 8, but it will allow you in run Versions 6, 7 or 8.
Thanks
-Ryan
Userlevel 2
Yes, the NMS-BASE-250 license allows you to install Extreme Management Center and manage up to 250 devices (managed IP's). I would, however, recommend installing the latest version of EMC, 8.0. There are quite a few improvements over version 6.3.
Reply
