is there any way to export the list of APs with radio channel and power settings from the controller?
I need a way to quickly and regularly document the settings on ~700 APs, is there any way to export the list of APs with radio channel and power settings from the controller?
Active APs from reports tab. Export as an xml and use excel to open.
Also, if you can SSH to the controller, type in shell and enter this command (you can also just type in show ap_inventory, but this will allow you to redirect output to a file.
/var/controller/bin/chantrysh -c "show ap_inventory" > ap-list.txt
the .xml file works perfectly, thanks so much!
Userlevel 6
You can use snmp to get this information. Netsight does have bflexviews with such info I believe...
Reply
