Links between devices in Extreme Management
Hi all,
How to add multiple links from one port in a switch to many virtual machines on VMWare?
On the picture bellow you can see the problem:
I have one port in switch which is connected to server with many VM. I would like to monitor status of all links to virtual machines. Unfortunately I cannot add one logical link form the switch (VLAN) to more than one device. Is there solution for that?
On the picture I have one link as physical, one as logical and that’s it. I cannot create new link in this same vlan or port to V2110.
192.168.31.10, 192.168.41.2, 192.168.31.20 are all on one server.
Userlevel 6
Hello,
You should be able to create manual links:
https://gtacknowledge.extremenetworks.com/articles/Q_A/Is-it-possible-to-create-manual-links-between...
Thanks
-Ryan
Userlevel 4
Yacobucci, Ryan wrote:
Hello,
Thanks
-Ryan
Hello Ryan,
Can you re-use the switch port as an endpoint of many links for that?
Kind regards,
Tomasz
Reply
