Netsight Policy Problem with VM XOS
I'm running XoS VM with GNS3 and add the XOS switches in the Extreme Management center (Netsight) when I tried to add devices to the policy domain, Error said that the XOS switches will not added, any one have a solution for this problem?
1 reply
Userlevel 6
The list of devices supporting Extreme Policy does not contain virtual switch. You need physical switch for policies.
Reply
