Question
Problem with Microsoft Edge Chromium 83 and NETSIGHT
  • 17 July 2020
  • 3 replies
  • 135 views
Hello,
we have the problem that the Netsight web console with the new Microsoft Edge with Chromium does not display some objects. For example the list under "Access Control" - "Configuration" does not appear. A Java error occurred. We have no problems with Google Chrome. Do you need Java and if so, which version of Open JDK / JRE? I think it would be completely HTML5.
Many thanks for the help!
Userlevel 6
Hello,
Per releases notes here are the supported browsers:
You shouldn’t need Java for the WebUI.
I don’t believe we support the newest Edge with Chromium browser.
Thanks
-Ryan
Hi Ryan,
thanks for your answer. I use the WebUI and have the version AdoptOpenJDK 12.0.2.10 with hotspot as Java Runtime. I see Edge Chromium as the standard browser for the future, especially in the corporate environment. Except for Netsight, I haven't seen any difference compared to Chrome. Will there be Netsight as HTML5 without Java infuture?
Thanks
Michael
Userlevel 4
Hi Michael, we are working on switching to all HTML5 before Java goes out of use this December. I do not have an exact ETA for that at the moment however.
Reply
