Purview - error communicating with remote flow collector
  • 22 September 2015
  • 1 reply
  • 723 views
Userlevel 6
Hi, all!
Have some issue:
VMWare ESXi 5.5
on this hypervisor I install Netsight 6.3, Purview 6.3 and V2110 09.21.02.0014.
Can't add normally tap interface of Purview.
Have a network 192.168.70.0 - management network for V2110 and network for Netsight.
Add this network as management for Purview.
have a network 192.168.0.0 - data network for V2110 - connect to switch with AP3805.
Trying Purview topologies 1,2 and 3 but still can't see V2110. Add phisical interface which look in network 192.168.0.0 but in Purview "ifconfig" I can't see this interface.
In V2110 - Netflow/MirrorN - Traffic Mirror L2 Port - have only None option.
May be I have to add only 1 interface 192.168.0.0 to Purview. ( But then I'll wouldn't see Purview in Netsight.
Or what I'm doing wrong?
Help please!! question is quite urgent!!
Thank you!
1 reply
Userlevel 6
Hi AlexandrP,
It sounds like the VM for Purview only has one adapter, and you would like to add a secodary interface for the tap, to be used betwen the v2110 (which also needs extra adapter)?
https://pubs.vmware.com/vsphere-51/index.jsp?topic=%2Fcom.vmware.vsphere.vm_admin.doc%2FGUID-47765AC...
here is VMware solution to do that. Additionally, the inteferace for the tap port, must be made into Promiscuous mode as well.
https://gtacknowledge.extremenetworks.com/articles/Solution/Purview-mirror-port-sees-only-broadcasts...
Reply
