XOS current power consumption
Userlevel 1
is it possible to show the current power consumption of an XOS Switch in Netsight?
Best Regards,
Stephan
Userlevel 4
Sure, there is a flexview you can launch against a switch, multiple switches.
Userlevel 7
There is a report available in Extreme Management Center in
> Reports > Reports > Device > Top Switches by Power
But there is no data shown for my 5x X450 and 1x X440 which I've in my lab setup.
Could you check whether you also get no data ?
I'm running v7.0.3.11
Userlevel 1
Hi guys,
I just had a look into your suggested solutions. This is what I got:
XOS Power Supply Summary:
The values at "Input Power Usage" are always "0"
Report:
Values only under Power consumption
Custom report:
I think this is the only thing that worked properly.
Reply
