LED S Series Chassis
Userlevel 2
What does the LEDs under the USB-Ports on an S-Series Chassis indicate? I can't find information in knowledge base and HW installation guide.
should the LED always green when a fabric module in this slot is installed?
Userlevel 4
Peter,
The LED should be on when there is a board powered up in the slot associated to that COM port and USB. For example the S3 chassis has three COM ports one for each slot. In contrast the S4 only has two representing the two fabric slots marked with a red band (slot 2 and 3).
I hope this helps.
Userlevel 2
Hi Daniel,
thanks for your reply. The reason for my question; I've a S8-Chassis with 3 installed fabric-modules (slot 4,5,6). But only the LEDs on the COM/USB-ports for slot 4 and 5 are on. LED for slot 6 is off. Module 6 is active and working (more or less). It has some strange effects on 2 or 4 ports. The questions is, can this even indicate an issue with the card?
Reply
