Question
problem with policy based routing in enterasys n3 and s8
i have an N3 (firmware 05.42.10) with advance routing license n-eos-l3 and it works well with policy based routing.
Now i would use a similar configuration on a S8 (firmware 08.61.02.0002) but it doesn't work, in particular the same linux machine (a nat for packet arriving on the internal interface based on pbr) does not work even if the show route-map probe command says that next-hop is up.
Someone can help me? Thanks
Renzo
Be the first to reply!
Reply
