Question
Connecting Cisco IP phones to Extreme Summit X-460 switches
  • 7 January 2014
  • 1 reply
  • 588 views
Userlevel 4
Create Date: Apr 9 2013 7:01AM
I have connected Cisco IP phones to Extreme X460 switches, but my Cisco Phones is not getting IPs form the Voice VLAN. As I have already configured all the data & voice vlan in my blackdiamond 8810 core switch. Any suggestion please will be highly appreciated.
MA Khan (from mdatherkhan)
1 reply
Userlevel 4
Create Date: Apr 10 2013 1:35PM
If the phones support LLDP use the following to bring up a cisco phone in the voice vlan. You will need to adjust ports as needed for your switch and/or blades that you want to configure for LLDP.
configure lldp port 1-52 advertise system-name
configure lldp port 1-52 advertise vendor-specific dot3 mac-phy
configure lldp port 1-52 advertise vendor-specific med capabilities
configure lldp port 1-52 advertise vendor-specific med policy application voice vlan voice dscp 46
configure lldp port 1-52 advertise vendor-specific med power-via-mdi
enable lldp ports 1-52
(from Greg_McKillip)
Reply
