EPS-500 External Power Supply Unit (Model 10911) compatibility with the Summit X440 48t and 48P.
Hi, Can anyone tell me if the EPS-500 External Power Supply Unit (Model 10911) is compatible with the Summit X440 48t and 48P. The pins look like they will connect but I just wanted to be sure.
Userlevel 7
Hi, doesn't look like if you check the datasheet...
http://learn.extremenetworks.com/rs/extreme/images/Summit-X440x-DS.pdf
-Ron
Userlevel 5
I do not believe that the EPS-500 is compatible with the X440, there is firmware that it needs to work correctly and the 500 is an old unit with a fixed power supply. The one compatible is the EPS-C2.
Userlevel 4
Hi Sandeep,
EPS-500 External Power Supply Unit (10911) can be used for below models.
• Summit X150-24p switch
• Summit X250e-24p switch
• Summit X350-24t switch
• Summit X350-48t switch
• Summit X450a-24t switch
• Summit X450a-24x switch
• Summit X450a-48t switch
• Summit X450e-24p switch
• Summit X450e-24t switch
• Summit X450e-48t switch
Thanks,
Suresh.B
Yes it is compatiable
Regards
Syed Arshad
Userlevel 7
Regards
Syed Arshad
Have you used the EPS-500 successfully on one of your X440s?
Regards
Syed Arshad
Nope. My bad it doesn't i beleive. 440 support RPS-500p.
Apologies
Reply
