Question
Extreme Inline-Power for Cisco IP Phone 7960
Userlevel 4
Create Date: Sep 30 2013 12:30PM
Good morning,
I'm changing Cisco 4006 for some Extreme Switches PoE. After the change I notice that Cisco IP Phone 7960 do not turn on via PoE. I connected it back to Cisco 4006 PoE port and check the corresponding mWatt used by Cisco, here the display:
Console> (enable) show port inlinepower 5/3
Default Inline Power allocation per port: 6.00 Watts (0.11 Amps@51V)
Total inline power drawn by module 5: 18.36 Watts ( 0.36 Amps@51V)
Port InlinePowered PowerAllocated
Admin Oper Detected mWatt mA@51V
5/3 auto on yes 6120 120
I try to modify the corresponding mwatt on extreme switch with this command: configure inline-power operator-limit 6120 ports 3.
Now I can't turn on that Cisco IP Phone, and since I'm new working with Extreme Switch I may be missing something.
Thank you in advance.
(from j.urena)
1 reply
Userlevel 4
Create Date: Sep 30 2013 2:13PM
Hello J.urena
If I am not mistaken that phone uses Cisco's proprietary pre-standard PoE. Try using the command enable inline-power legacy and see if that helps.
Thanks
P (from Paul_Russo)
Reply
