Facing issue to in BD 8810 switch Backup issue.Please help
Hi Friends,
I am facing issue with BD 8810 switch .whenever trying to take backup its showing error.
Used commands :-TFTP PUT [i] -V VR-Default Primary.cfg
Userlevel 7
What is the error? Are you on the right VR?
Failed timeeout
Userlevel 6
Sumit,
What version of EXOS are you using? The correct syntax of the command in recent versions is
tftp put vr vr-default Primary.cfg[/code]
dflouret wrote:
Sumit,
Daniel,
I am using same commands .
my current version is primary version 15.1.2.12 .
secondary version 12.7.1.3.
Userlevel 4
Sumit,
I would first try to ping the TFTP server from the switch. If you can ping from the switch, check your TFTP settings or check to make sure your firewall is not blocking the communication.
Hernandez, Joshua wrote:
Sumit,
Dear Hernandez,
I am able to ping TFTP server and no port is blocking by firewall.
i have taken other switch backup with same TFTP server.
Userlevel 5
Sumit,
If you are doing a backup to the tftp server I would opt to do it via a .XSF or a text file, I find them easier to use and more reliable if you ever need to restore. You can do that with the "upload configuration" command - it will upload a TXT file of the total config. Here would be the complete command:
upload configuration 10.65.41.4 bill.xsf vr "VR-Default" (substitute IP address and vr where neccessary)
Uploading bill.xsf to 10.65.41.4 ... done! (Showing completion...)
This creates a bill.xsf text file on the TFTP server that you can modify and copy back. You can cut and paste or you can "load script bill" to restore.
Bill
Dear Bill,
Please let me know what is difference between Upload configuration & TFTP put commands.
Userlevel 6
Hi, Sumit!
1. Difference between Upload and tftp put commands in file format in uploaded file.
Upload - .xsf file
tftp put - .cfg file
2. Have you trying put file to another PC? It's can be trouble with firewall in your PC/lap-top.
Thank you!
Alexandr P wrote:
Hi, Sumit!
Upload - .xsf file
Thank you!
Dear Alexandrp,
Is it rite syntax to take backup of extreme switch
TFTP Put[i] -v -vr-default primary.cfg
Alexandr P wrote:
Hi, Sumit!
Upload - .xsf file
Thank you!
Dear Alexandrp,
Thanks for your valuable support .
now i am able to take backup .
Regards
Sumit
Userlevel 6
Alexandr P wrote:
Hi, Sumit!
Upload - .xsf file
Thank you!
If you use vr-Default main ports - then "tftp put [i] vr vr-Default primary.cfg"
If you use MGMT port of MSM module - then "tftp put [i] vr vr-Mgmt primary.cfg" or do not specify VR.
Also you have to look that you home folder in TFTP server is configured right.
Also you have to look with "ls" command that primary.cfg is present in switch
Userlevel 4
https://community.extremenetworks.com/extreme/topics/restore_from_backup-10oqux
Refer above blog. It may clear your all doubt regarding configuration backup.
Reply
