Question
Flow control issue
  • 20 May 2019
  • 0 replies
  • 445 views
we are using EXOS version 22.5.1.7_patch1_3
switch x620 16p.
we have tried to enable flow control in the switch, and we can see the AN complete with flow control enable.
we enable the tx_pause frames in one port, and from some reason we can see very low throughput.
all the other configuration are the default
can you advice? what we are missing here?
Thanks,
Yoni.
Be the first to reply!
Reply
