How to check Serial No. and System No. of EPS from Extreme Switches? Thanks.
Userlevel 3
How to check Serial No. and System No. of EPS from its connected Extreme Switches?
Is there any way to check Serial No. and System No. of EPS (External Powersupply) from Extreme Switches.
Thanks.
Userlevel 5
show version[/code]
In the output, you should see a section showing connected PSUs and their associated serials
Userlevel 3
Kawawa wrote:
show version[/code]
Slot-1 x250-sw01.13 # show version
Slot-1 : 800211-00-03 0943G-81649 Rev 3.0 BootROM: 1.0.3.5 IMG: 12.1.3.14
Slot-2 : 800211-00-03 0943G-81622 Rev 3.0 BootROM: 1.0.3.5 IMG: 12.1.3.14
Slot-3 :
Slot-4 :
Slot-5 :
Slot-6 :
Slot-7 :
Slot-8 :
Image : ExtremeXOS version 12.1.3.14 v1213b14-patch1-6 by release-manager
on Tue Sep 8 13:07:40 PDT 2009
BootROM : 1.0.3.5
Slot-1 x250-sw01.14 #
Slot-1 x250-sw01.15 # show version detail
Slot-3 :
Slot-4 :
Slot-5 :
Slot-6 :
Slot-7 :
Slot-8 :
BootROM : 1.0.3.5
Slot-1 PCB INFO: 8FBCPU...0A2 G67225662
Subsystem PCB INFO: 8EVTPA24.1A1 G67292039
Slot-2 PCB INFO: 8FBCPU...0A2 G67225884
Subsystem PCB INFO: 8EVTPA24.1A1 G67291940
Slot-1 x250-sw01.16 #
I cannot see any section showing connected PSUs and their associated serials. Thanks
Userlevel 7
Hi Paul,
I don't think you can retrieve the EPS information from the switch, but I could be wrong.
I'll see if I can get our lab team to test this on Monday morning to help be sure.
I also noticed that you're running EXOS 12.1, which is rather old. I'll see if this makes any difference in the results.
Userlevel 3
Thanks Drew,
Appreciate your help very much.
Userlevel 7
Paul wrote:
Thanks Drew,
Hi Paul,
I haven't forgotten about this. I've got to dig up the right cable to connect the EPS to the switch. While I'm looking, are you using the EPS-160 or EPS-T? Same cable, just a different External PSU... we have both.
Userlevel 3
Paul wrote:
Thanks Drew,
We are using (2x EPS-160 in a 1U Rack) EPS-T External Power Tray
model: 10906
Userlevel 5
Hi Paul, I am using a X460, which gives me an output like the one below:
Switch : XXXXXX-XX-XX XXXXX-XXXXX Rev 2.0 BootROM: 2.0.1.7 IMG: 15.6.1.4
SS-B-1 : XXXXXX-00-X1 XXXXG-XXXXXX Rev 1.0
PSU-1 : EDPS-XXXAB A-S9 XXXXXX-00-03 XXXXE-XXXXX
PSU-2 :[/code]
You're on a X250, running version 12. I am not sure you'd see a output similar to what I have probably because the X250 doesn't have a field replaceable (modular) PSU, but again, I am speculating on this one. Will wait and hear back from the team!
Userlevel 3
PSU-2 :[/code]
Thanks Kawawa, for the information. Yep it might be system model and ver 12. Thanks.
Userlevel 7
Hi Paul,
I do not believe that the EPS will report serial numbers to the switch. However, I'll wait for the results of Drew's testing for a final result.
-Brandon
Userlevel 7
Hi Paul,
As expected, the X250 is not able to pull serial numbers from the connected External PSU. While looking for a cable, I asked one of our hardware engineers who happened to have the wiring diagrams... there's no data link between the EPS and the switch in this connector.
-Drew
Userlevel 3
Hi Drew,
Thanks a lot for your time and kind consideration. Its really helpful for us for this informative advice.
-Paul
Userlevel 7
Paul wrote:
Hi Drew,
-Paul
You're welcome Paul! Glad to help!
Reply
