Question
point to point inter vlan communication between extreme summit 48si and extreme x770
  • 22 August 2019
  • 0 replies
  • 270 views
I have created a point to point inter vlan communication between extreme summit 48si and extreme x770, but unable to ping, because of static mac and also the summit switch is taking default configss on the port, pelasehelp with tshoot and commands to delete the default configs and static mac in summit switch
Be the first to reply!
Reply
