Problem with CPU and memory monitoring (MIBs)
Userlevel 3
Hi everybody.
I have some troubles with CPU and memory monitoring on the Solarwinds monitoring system. I've gotten interface statistics, sysname, sysdescription, but I haven't found CPU and memory information.
Then I try to find ExtremeXOS MIBs, but unfortunately I haven't found it too.
Where can I find XOS MIBs? Can you give me advice about SNMP monitoring?
Userlevel 6
Hello EyeV the MIBS for XOS are on the esupport support site. If you can't login then call TAC at 18009982408. P
Userlevel 4
Few useful SNMP OID,
Name extremeCpuMonitorTotalUtilization
OID .1.3.6.1.4.1.1916.1.32.1.2
Name extremeCpuMonitorMaxUtilization
OID .1.3.6.1.4.1.1916.1.32.1.3.1.12
OID .1.3.6.1.4.1.1916.1.32.1.6.0
OID: .1.3.6.1.4.1.1916.1.32.3.0.1
OID: .1.3.6.1.4.1.1916.1.32.2.2
Name extremeMemoryMonitorSystemFree
OID: .1.3.6.1.4.1.1916.1.32.2.2.1.3
OID: .1.3.6.1.4.1.1916.1.32.2.2.1.4
OID: .1.3.6.1.4.1.1916.1.32.2.2.1.5
OID: .1.3.6.1.4.1.3375.1.1.78.0
OID: .1.3.6.1.4.1.3375.1.1.77.0
Hi Summit,
The values that you post are applicable for BD8810 ? could you provide details of how to achieve the following:
Need the oid values for BD8810 to monitor on Cacti: Current CPU Utilization per MSM, Memory Utilization (System, User, Free) per MSM, System Storage (Used and Free), and per VLAN L3 Utilization.
However, If is necessary I can open a case.
Userlevel 3
Thank you Paul and thank you Sumit. I use SNMP-walk and I don't find any 1.3.6.1.4.1.1916.1.32.1 or 1.3.6.1.4.1.1916.1.32.3 OIDs. My list begins from .1.3.6.1.4.1.1916.1.32.2.2.1.3.1.
Should I change something on the switch or my configuration is enough.
configure snmp sysName "xxx"
configure snmp sysLocation "xxx"
configure snmp sysContact "xxx"
# Module snmpMaster configuration.
configure snmpv3 add community $MyRWCommunity$ name $MyName$ user v1v2c_rw
configure snmpv3 add community $MyROCommunity$ name $MyName$ user v1v2c_ro
configure snmpv3 add target-addr v1v2cNotifyTAddr1 param v1v2cNotifyParam1 ipaddress 172.30.0.6 transport-port 162 tag-list defaultNotify
configure snmpv3 add target-params v1v2cNotifyParam1 user v1v2cNotifyUser1 mp-model snmpv2c sec-model snmpv2c sec-level noauth
disable snmpv3 default-group
disable snmpv3 default-user
configure snmp access-profile mgmt-acl readwrite
entry ManagementACL {
if match any {
source-address 172.30.0.0/16;
source-address 172.20.0.0/16;
source-address 192.168.0.0/23;
} then {
permit;
[/code]
P.S. Thank you so much. You really help me.
Userlevel 3
Sorry, I've found it.
Userlevel 4
Can you let us know what information you found?
Userlevel 3
I've found OIDs in my snmpwalk list. Anyway OID .1.3.6.1.4.1.1916.1.32.1.6.0 doesn't work, but other OIDs from your list works perfectly.
We have issue with pooling system info (cpu, mem etc.) from X8 with Solarwinds. I also tryed to pull with Paessler and some other snmp tools. some of those OIDS are correct but some do not show usable info.
I have also troubles importing Extreme Networks MIB file to lot of SNMP tools. What is deal with that. What MIB/OID tool you use that can import Extremes MIB file correctly?
What OID's to use on X8?
Userlevel 1
Is there a config or concept guide on this one. I have summit switches and 8810's that need I want more viability using Solarwinds.
Userlevel 7
I'm not very familiar with the ins and outs of Solarwinds... Can you import the EXOS MIB into the program to help make configuration easier?
Userlevel 1
I believe so. They have a basic set but always seems like something is missing.
Is there a config guide or document for all the Extreme snmp OID's?
Userlevel 7
The MIB file is somewhat tied to each EXOS version. If you have access to esupport/extranet, you should be able to download it for your particular version. If you can't find it, let me know what version your EXOS gear is running and I can get it to you.
Once it's imported, you should be able to browse and search for specific areas of interest.
I'm not aware of a specific SNMP guide, though one may exist - sorry.
Userlevel 1
Ok Thank you.
Reply
