Question
Serious problem for snmp and ipv6
  • 7 January 2014
  • 1 reply
  • 685 views
Userlevel 4
Create Date: Sep 7 2012 5:08AM
Today i use summit x250 and 450 series switch and test get snmp infomation through IPv6,found if firmware was 12.x.x.x it w you will getill ok but when use version 15.x.x.x that switch will be reboot,so if you use 15.x.x.x version firmware don't through IPv6 get snmp information...................
from log you will get
09/07/2012 16:55:11.97 Process snmpMaster exceeded pre-configured or default crash rate
(from Hsu_LiPing)
1 reply
Userlevel 4
Create Date: Sep 7 2012 6:50AM
HelpmeCan you please open a case with TAC so they can verify this and see about a resolution?ThanksP (from Paul_Russo)
Reply
