summit x460 enable graphical web interface using management port
I cant enable web interface with my summit x460. I have tried creating Mgmt Vlan with ip 172.16.99.1 / 24 but when im connected using "Management Port" i can't ping 172.16.99.1 or acces web page (i set my laptop ip to 172.16.99.254 / 24). I also run and saved command "enable web http"
* Bud_1-X460.3 # show vlan
Name VID Protocol Addr Flags Proto Ports Virtual
Active router
/Total
Default 1 172.16.98.1 /24 ------------------------- ANY 0 /0 VR-Default
Mgmt 4095 --------------------------------------------- ANY 1 /1 VR-Mgmt
v1-KD 10 --------------------------------------------- ANY 9 /9 VR-Default
v3-CCTV 30 192.168.3.254 /24 ------------------------- ANY 7 /9 VR-Default
v4-SCADA 40 10.244.4.254 /24 ------------------------- ANY 1 /3 VR-Default
v99-mgmt 99 172.16.99.1 /24 ------------------------- ANY 1 /1 VR-Default
Flags : (B) BFD Enabled, (c) 802.1ad customer VLAN, (C) EAPS Control VLAN,
(d) NetLogin Dynamically created VLAN, (D) VLAN Admin Disabled,
(E) ESRP Enabled, (f) IP Forwarding Enabled,
(F) Learning Disabled, (i) ISIS Enabled, (L) Loopback Enabled,
(l) MPLS Enabled, (m) IPmc Forwarding Enabled,
(M) Translation Member VLAN or Subscriber VLAN,
(n) IP Multinetting Enabled, (N) Network Login VLAN, (o) OSPF Enabled,
(O) Flooding Disabled, (p) PIM Enabled, (P) EAPS protected VLAN,
(r) RIP Enabled, (R) Sub-VLAN IP Range Configured,
(s) Sub-VLAN, (S) Super-VLAN, (t) Translation VLAN or Network VLAN,
(T) Member of STP Domain, (V) VPLS Enabled, (v) VRRP Enabled,
Total number of VLAN(s) : 6[/code]i have also tried to
Userlevel 6
Hi Piotr,
The Management port is the "Mgmt" VLAN, just assign IP to it and see.
Thx! its working! 🙂
Reply
