X440-24t technical Specs about Max PacketSize is false? (serious problem)
  • 7 January 2014
  • 1 reply
  • 797 views
Userlevel 4
Create Date: Jul 30 2013 11:31PM
from its Specs it sayMax Packet Size: 12KB (Jumbo Frame Support),but for my X440-24t firmware 15.3.2.11 it MAX Packet size is 9216
I according Technical Specs buy these model switch, but why i can config jumbo size > 9216 ? (from Hsu_LiPing)
1 reply
Userlevel 4
Create Date: Jul 31 2013 7:16AM
I think there is an error on the web, in DSSumX440_1831.pdf -> Max Packet Size: 9KB (Jumbo Frame Support)
also the release notes for EXOS says:
Jumbo frames—maximum size supported for jumbo frames, including the CRC. - All platforms - 9,216
Jarek (from Jaroslaw_Kasjaniuk)
Reply
